1/4 Mile experience ???
mntngts99
Boise, ID, USA
Just would like to get some input from all you with expereiance under your belt.
I have a 99 GTS whith filter/tubes,cat-back,3.55.My G-tech came the other day so I went out to have a little fun. I left soft no spin, shifted soft 2nd/3rd no spin,Once in 3rd didnt hold back ran it hard through 4th. Made two runs best Time was 13.012 @ 117 mph. Did one 0-60 run at 4.9. Once I pratice my start what kind of E.T can I expect. Any info would be helpfull.
Brad
jcaspar1
Sacramento, CA
I have found the G-tech to correspond well with dragstrip times when done on the same track. It is easy to run in the low 13's in a Viper without practice, missing a shift or with poor traction. The mph is a little concerning as my 97 GTS runs 123-125 mph on the G-Tech (177-118 mph at strip). You may have been running on a surface that was not completely flat. The first time I was ever at a drag strip, the best time I ran was a 12.8. By the second I was down to a 12.4. Several trips later my best was a 12.2. Keep practicing and you may want to consider a dyno or drag strip run to be sure your motor is putting out proper power.
SKY1960
