1" Lowering Instructions
jwbond
Re: 1\" Lowering Instructions
why not just post them for all to see?
2002_Viper_GTS_ACR
Charlotte, North Carolina
Its not an inch. R u nuts? You talking about the lowering caps? Matter of fact, its not even 1/2 an inch its more like 4/10 of an inch. I measured the difference between the originals and the smaller ones.
Jon
T
TedK
Southern CA
This is a request for the 1" seat lowering instructions.
Ted K
Flash1034
San Juan Capistrano, CA
Jon (2002 Viper GTS ACR), Ive noticed you add nothing useful to your posts. You dont offer helpful advice or information to the thread. You, Sir, are simply a sniper. Dont you have something better to do?
Flash
twinturbo3150
Flash, you can take your observations and shove them up your tail pipe for all I give a damn.
Jon
I find this information useful, 1 for Jon :smirk:
Racer Robbie
Guilford, CT-USA
To TedK, I have the instructions for the Northwind 1" kit. If you give me a fax number or mailing address I can make you a copy and get it to you. I have no way to scan it.
Robbie
compcoupe21
But what if Flash has an SRT, wouldn't you mean side pipe then? :buttkick:
T
TedK
Southern CA
OK, thanks to Robbie for faxing over the instructions.
Ted K
johnk
Laplata, Maryland
Could someone share the installation procedures? How difficult and time consuming is the installation? Thank you
Mike Dolan
Northern California
John,
It's pretty easy, you will need 13mm & 15mm sockets, and a long extension.
My memory is fuzzy on this, but I think you'll need a T50 torx to remove the seatbelt conector. Check this out as I am not really sure, sorry my memory isn't better.
Slide the seat all the way forward, and you can access the rear nuts. Remove them, then slide the seat all the way back, remove the front bolts, and the seat will come right out. Don't forget to unplug the seat belt warning wires.
Once the seat is out, you remove the rail assembly - it's quite easy, and if I recall correctly, you need a 13mm socket to do this.
Once this is removed, connect the new rails, and reinstall the seat.
Total time should be less than an hour.
Hope this helps,
Mike Dolan
Copperhead245
Jefferson, NJ
Hey Ted,
I installed the kit a couple of months ago, just as Mike said - less than an hour (and you do need the torx driver). If I remember, the instructions referenced pictures that are available from Northwind - which I got and just emailed to you...
Ron
Copperhead 245
Andrew/USPWR
W. Palm Beach
Ted, I may have the 1" seat lowering instructions still around if you still need them.
And I have a set of the 4/10th lowering caps for sale if anyone's interested? $100
T
TedK
Southern CA
Ron & others:
Thanks for the input. My seat actually went in on 12/5 with no problems, JOHNK revived this thread on 1/18.
johnk
Laplata, Maryland
Thanks all, the seat lowering kit installation sounds pretty straight forward, ordering mine now..
Take care
2002_Viper_GTS_ACR
I'll take 'em. I think they would look great on my Dads viper. The already look great on mine :) :2tu:
Cerevo
