100% stock '99 ACR dyno w/air & fuel ratios
VENM8R
The Last Frontier
100% stock \'99 ACR dyno w/air & fuel ratios
These are the best I can load them up at. The dynojet program does not have any provisions for saving to file. Anyone know a way around that? I printed to file and used Corel 10.
(I forgot to add: These are SAE corrected and all 3 runs there wasn't a fan used. I hope that would be the reason the power & torque went down on each successive run).
Is the air/fuel ratio typical of this model?
GPII
Jason Heffner
Sarasota, Florida
Re: 100% stock \'99 ACR dyno w/air & fuel ratios
What were the engine temperature differences between these runs? It looks like it may be running a little rich in the higher rpms but it doesn't seem to have hurt power any. Good numbers!
V
VENM8R
The Last Frontier
Jason, this the first dyno I had done in years and I thought they were recording that type info; but I never received any if they did (I do know that the motor was running hot).
I would have liked that info to compare for when I get the Roe Supercharger installed.
Jason Heffner
Sarasota, Florida
Well, you've got some good numbers to start with. Be sure and let us know how it turns out.
Sean Roe
Jacksonville, FL
Sure starts out lean at the beginning of the run. Doesn't even get to 14.0:1 (which is still quite lean for full throttle) until 3,500 rpm. Was that measured after the cat? That's leaner than most I've seen. Might want to put a new fuel filter on it before you install the Supercharger.
Sean
<FONT COLOR="#ff0000" SIZE="1" FACE="Verdana, Arial">This message has been edited by Sean Roe on 11-21-2002 at 05:57 AM</font>
Jack B
NE Ohio
To export the Dynojet graph - call up the pulls then right click on the graph area. It give you a choice of bitmap or meta file.
Make sure he uses a wideband sensor and install it in the forward O2 well - you will see a diff. Print the data chart and if he had a coolant temp probe you will see a correlation in the hp and coolant temp. The fan only impacts the hp as far as dropping the coolant temp between runs.
V
VENM8R
The Last Frontier
Sean Roe:
"Sure starts out lean at the beginning of the run. Doesn't even get to 14.0:1 (which is still quite lean for full throttle) until 3,500 rpm. Was that measured after the cat? That's leaner than most I've seen. Might want to put a new fuel filter on it before you install the Supercharger".
Sean
Yes, I believe that it was measured from the tailpipe (there was a device placed into it). Thanks, I will look for a new fuel filter Sean! GPII
I'll try that Jack B, Thanks for the info! GPII
Sean Roe
Jacksonville, FL
Measuring the air / fuel ratio after it has pased through a catalytic converter will give you a leaner reading.
Sean
SKY1960
