12.01 @ 123.9
boosted349
06 srt10 coupe my best time is 12.01 @ 123.9 out of 10 passes completely stock with a 2.03 60ft. with run flats. i have done a best of 1.91 60 ft
Hamrhead
eastern, Pa
Definitely some nice MPH!!
I thought I had a strong '06 Coupe when I went 11.90 at 122.xxmph stock.
I've since made a few mods - DC Tune/170 t-stat; Corsa Track, Green Filters; PS2 Tires and 3.55 Gears.
MY best ET since the mods is 11.85 at 119mph w/ a 1.85 60', but slipping and sliding through 2nd and 3rd. Mid-Track was not very sticky that day.
But about a month ago we went to the strip again. ~75 degrees, Sunny, Beautiful Day! Though it easily felt as if it were over 80 degrees on the blacktop!
I managed to run 12.0x four times in a row, with MPH anywhere from 123 up to my new best MPH of 124.65 (12.001ET). No powershifting and my 60's were about a 1/10 slower at ~1.95. Also, I was spinning about 5-10ft. when shifting into 2nd gear.
With the MPH, I'm reasonably certain it has an 11.5 in it,,, on the right day.;)
Twister
Very nice...Boosted..Please tell me she's still stock and your gonna try some more...With 124 mph trapp speeds you could defiently get some 11 second passes in stock and place well on the stock gen3 fast list
Roysviper
Milton,FL
I don't know what my current Viper will run in the 1/4mi but as soon as I can take it to a 1/4 mi track I will. I have only made 3 passes in the 1/8th mi at my home track, HOLT FLorida in Nov. Here is my best pass and I know it will run several 10s faster..
60 ft------1.5742
330 ft-----4.4149
594 ft-----6.3757
1/8 ET-----6.8129
1/8 MPH----102.94
My Viper is 1996 ROE S/C GTS. It use to belong to Mike Robbins and he has done an awesome job on the car as far as I am concerned.I am working on my driving so I can get the maximun out of my car.I am 62 yrs old so my reflexs arn't what they use to be, ha...I LOVE to DRAG RACE (at the track).. :drive: :drive:
Happy Vipering to all and "MERRY CHRISTMAS"
Roy V09407
Keep working at it! An SRT should be almost 3/4 sec faster than a GTS.
__________________
GTS Dean - Team Texas
'96 GTS - EMI Penske 3-ways, Aeroquip brake lines, Dilusi brake deflector kit, HMS carbon fiber airbox, oil pan baffles, aluminum flywheel, rear X-pipe, '71 GTX exhaust tips. 414/452, [email protected]
-FROG-
Austin, Texas
Nice traps. You can get some mid 11 sec runs with that car as it is. May take a little practice but it should do it. Probably gotta feather that clutch out of the hole to keep the tires from spinning though.
Canyon707
Napa California
I ran 11.7 on Nov 29 at the NHRA Summit Racing Bracket Drags at Infineion raceway in Sonoma. 82 degrees temp. This is my best time in my 04 Viper my bolt on mods are K&N, X-Metal TB, Corsa, DC mail in tune, Magnacor wires, B&M Short shifter OS Giken Dif. with 3.55 gears, MT Drag radials running 12 lbs of air. mph 120
Viper123456
