15 inch race rotors
Rickman6
Sweden
I'm looking at upgrading my GTS with 15 inch race rotors front & 14 inch rear....
Does anybody know where I can get hold of a good (used ) set?
The front being more important as I can use standard SRT10 14" rear for the time being..
Thx :)
R
Rickman6
Sweden
What brand is your track wheels? I've test mounted one 15"race disc and my wheels but without the Srt10 caliper and it's tight but looks OK! I also have a friend that has the stop tech 14" kit and the same wheels as me so I'll ask him about clearence...
97snk
So you can mount a 15 inch rotor in place of a 14 inch rotor if desired with the SRT front caliper?
R
Rickman6
Sweden
If you have big enough rims you can mount 15" rotors with SRT caliper no problem...
97snk
I found a company that can make a custom 15 inch rotor. I m going to see if I can get a custom bracket made. How big of a wheel wheel would a 15 inch rotor require? My current wheels are 19's up front.
R
Rickman6
Sweden
If you have 19" rims upfront there should'nt be any issue using a 15" rotor ...unless you have an insanely huge caliper...
MTGTS
Orlando, Fl
I ran a 15" rotor on my old TT 350z. I had to run 20's but that was mostly due to the 12 piston calipers. You'll prob be able to get away with 19's if they have the correct offset. Just won't be a lot of room for airflow around the brakes
xeng yang
