17" E.T. Streets are now avalible .................
1TONY1
Dalton Ga. (Chatt. Tn.)
17\" E.T. Streets are now avalible .................
It's been over a year in the approval process. They will fit nicely on a 10" front wheel, I wouldn't run them on the 13" wheel.
Tom Welch
Blairsville, Georgia
Re: 17
What about a rim for the bias ply tire that has to go on the front? Sounds like a plus for Viper owners with stock wheels for sure.
Tom
sun diego
Re: 17
vettekiller, many have and some haven't hit the wall with that combo.
For your safety buy the extra rims and the skinnies for the front. They have less drag, too which helps
CHAD
Sarasota, FL
Re: 17
I used to run my old Trans Am ('88) with R1 compound radials on the front and ET Streets on the rear. It ran high tens at 3400#'s and was more work on the top end than it was out of the hole. It is a bad idea, from my experience, to mix tire types. I was just too cheap to buy new wheels back then.
You can't beat the Purner/CCW packages for drag racing. Safer and stickier, IMHO.
Chad
jason427
Indialantic, FL
Re: 17
Please go with a CCW Drag setup!
I did the et drags with radials up front on my 670hp Cobra replica and almost killed myself. It was out of control on the top end. Combine that with a 90" wheels base made for some tense running.
I raced a few weeks ago with the Viper and the CCW Drag setup and it was AWESOME! Stuck like glue, and was straight as an arrow on the top end. Don't risk it. Get the package and you will LOVE it.
Just my .02 worth.
Jason
