18" BFG Drag Radials
SJT97GTS
St. Louis, MO
18\" BFG Drag Radials
I want to get others input on these...
I own a pair and they are currently mounted on my car (it's been a week or so now). Is it me (maybe not enough air or something) but are these things scary to drive on?
For example, when going 70+ on the highway, are these things WAY TOO TOUCHY when steering? Maybe I don't have enough air, but these things make my car much harder to drive.
By the way, it wasn't wet outside or anything, just normal driving.
Cudaman
USA
Re: 18
I have been 135mph in 10.5 sec, they handeled great (on dragstrip @ 15.5 psi). Daily driving up to 155 mph on 32 psi. They are not rated a Z rating so I would not drive over 110 mph for long extended periods.
Cudasman :usa:
JonB
Legacy\Supporting Vendor
Columbia River Gorge
Re: 18\" BFG Drag Radials
FLEXIBLE SIDEWALLS are the culprit, that, and mis-matched front treads. The sidewalls give for a reason, and that reason is NOT the best for spirited driving othar than in a straight line........
Stiffen the sidewalls: Go with sidewall max less 5 lbs for street driving. Swap em out after racing, and drive 4 matched-tread tires.
Whats REALLY scary is the highway exit/entrance ramps.
J DAWG
MS
Re: 18
What psi should you run in the BFG's?
At the track just as Cudaman stated. I run around 15psi.
On the street I would probably put 27 to 28 psi, but I don't use them on the street.
Moundir
Ny
Re: 18
what if you are racing on the street from a dig what then lol Just curious of course cause street racing is dangerous and kills millions of people every year :(
Missjazzyfitness
