1992 battery replacement
Janse
Esbjerg
Sounds like a stupid question, but have anyone replaced the battery in a 1992 Viper.
Tried to day, to replace the battery, but could not get the battery out of the battery tray and through the hole in the trunk. The bounderies/structure of the battery tray makes it impossible for battery to get through the hole in the trunk.
What do I do wrong ?
Picture taken under the car of the battery tray structure that causes my problems
viper209
Over the last 25 years have replace many many batteries in my 92
Not an action that can be explained. You need keep sliding and tilting. Eventually you will find the right slide - tilt-lift. Repeat till successfull
HVIPER
Wisconsin
Have a 1993 which I bought new. have taken battery out many times. make sure the hold battery down bar is out of the way. Like V said slide, tilt and left.... the fact that you have to lean over and into the the vehicle while twisting and pulling does not make it easy.
Dale04SS
