2001 gts hood on a 96rt/10?????
99 R/T 10
Enterprise, AL USA
Yes, it should fit, but I believe there are differences (small as they may be) in all the hoods. So you may need to do adjustments to make it look right.
dave6666
If you do get into the situation where you need to re-align your hood, there is some excellent information to be found here using the search terms of "hood alignment."
Good luck!
xeng yang
