Chris, if you mean "done correctly" in terms of fluid used, check your power steering fluid...if red, likely ATF+4, if clear, likely the older Mopar Power Steering Fluid.
I STILL HAVE A PROBLEM with the wording on the TSB that declares steering fluid usage, however...especially as the actual RECALL that recommends using the old MS-5931 is dated three months AFTER the TSB...as in November 2003!! DON"T EVEN ASK ME TO EXPLAIN what the TSB says about 92-02 Vipers(very confusing).
Service Bulletin Number 19-005-03 dated Aug. 29, 2003 codes 2003 and 2004 Viper SRT-10's as "ZB"...then proceeds to say that the "FACTORY FILL POWER STEERING FLUID" and "APPROVED SERVICE POWER STEERING FLUID" were and are BOTH MS-9602 (that is ATF+4)...however, OUR own 2003 SRT-10 had "clear fluid" in it from the get go...so, already, one sees an element of mis-info in the "Steering TSB".
By the way, MS-9602 is P/N 05013457AA in the single quart size.
I personally find this unsettling.
We did check a 5/04 build date 2004 SRT-10 on the showroom floor today and found "the red stuff" in the Power Steering.(presummably, ATF+4). One can only wonder WHEN the change REALLY took place as the techs here have seen "clear fluid" in many(if not all) 03's to date...prior to ther recall work...noting that MANY of the same cars STILL HAVE Mopar Power Steering Fluid (MS-5931 which is P/N 04883077) AFTER the recall was completed as per the published instructions.
So, should ALL 2003 and 2004 Viper SRT-10's have their Power Steering changed to MS-9602 NOW...and, if "post-recall" with MS-5931 in place, I am sure that there are those who will ask "WHO will pay for change"???
While Techs in whom I place a LOT of trust have pointed out that there is likely no emergency here, it would be GREAT to get this SORTED OUT once and for all, in my opinion.
SRT,(formerly PVO and Team Viper), can you advise???
THANKS, in advance.
