2006 Viper Engine Oil Level
domcall
I am doing an oil change and it's so hard to check the level on the dipstick, does anyone know how much oil I should put in, thanks.
Flexx91
Houston, Texas, USA
Why is it so hard to check the level on the dipstick? Its like any other car. My car takes exactly 10.5 quarts but I still check the oil level.
Hamrhead
eastern, Pa
One thing I found that is very important with this car (also when I had my SRT Ram) is make sure you are on a level surface when checking the oil. A slight angle side to side, or front to back, seems to make a big difference on the dipstick.
I just changed my oil and filter a few weeks back - 10 quarts and it's perfect.:D
Chopper
Williamsburg, Va.
I asked this same question awhile back. My 06 manual says 10 qts. I read somewhere that it's 10 1/2. My dealer says it's 11. I called the Dodge help line, and the guy looked it up in the manual.I thought, geez, thats the best that they could do? Half assed.
Viper X
My 2006 SRT-10 likes about 10.5 quarts at each oil change with filter. Just check it after it's been run a bit if you only add 10 quarts.
I also fill the oil filter (as much as possible) before installing it to try and avoid a dry start.
As for checking the oil level, turn the dipstick over and check the level on the back side, it's much easier to see.
Dan
xeng yang
