2010 Valve Stems
Y2K10 SRT#39
Olympia, WA, USA
I have had a gen 2 and 2 gen 3's, and now I have a 2010 Vert with the 5 spoke wheels.
I have never had a problem putting air in the tires of any of my cars until now. The old 120V air pump I use won't put any air into the tires.
What changed and in what year? My 03 and 05 gen 3's did not have a problem with my compressor.
And-
Just how do I fix this situation? I searched using "Valve Stems" as the search topic, but I did not see my problem. The clamp I have holds onto the valve stem just fine.
Thanks in advance.
PBR
Jerry Dobson
Lenexa, Kansas
Nothing changed. In fact, I have to use the old DRB3 scan tool from the Gen3 to reprogram the TPMS sensors in the tires running on the Gen4. I guess what I am saying is that internally, they are the same as what you had. Does your pump work on other cars?
Flexx91
Houston, Texas, USA
Correct. Nothing has changed as the TPMS wheel sensors are the same from '03 to '10. If you haven't already seen a TPMS sensor, the valve stem is integrated.
rlamorte
