2013 flywheel
MTGTS
Orlando, Fl
Why not just get one of the chromoly's for the same price as the aluminum's? Still weighs 10lbs less and chromoly > aluminum. You also don't have to wait for a part that's not even available
C
Chuck 98 RT/10
tampa, fl USA
After market flywheels can develop issues with the starter. I figure OEM has been tested thoroughly enough. Do you have chromoly Matt? If so, I assume you haven't had any issues. Does it have steel gear teeth?
MTGTS
Orlando, Fl
Camfab
SoCal
I agree with Matt, DC Performance carries them as well. If I'm not mistaken the Cromoly flywheel I saw at DC was one piece. I believe the photo in the link provided is actually a pic of an Aluminum Flywheel.
MTGTS
Orlando, Fl
yeah, I don't think the pic is correct as mine doesn't look like that
DanielR
The flywheel in the photo from the link is aluminum with (steel I think) inserts for the clutch surface.
The Chromoly flywheel from DC Performance is one piece. That is the one I installed when I did my clutch.
C
Chuck 98 RT/10
tampa, fl USA
The two issues I've read about are the teeth not be cut correctly and messing up the starter, and also read once where the ring separated from the flywheel.
SKY1960
