dun4791
Im sending my GTS to Underground Racing for a full SC build, and some of the members helped me decide on doing the heads. Now the only part of the build Im running through and cant seem to decide on is to stay with the stock displacement, or go stroker. Im doing the Oliver billet rods/ CP pistons, billet main caps, either way. It will be a strong, high boost capable engine. Does anyone know the ratio differences between these two choices?
Im concerned mainly with the side pressure on the block (even with the billet caps), the shortened piston, and the ground stock crank. My common sense approach in my decision making process says the stock displacement engine will be more reliable from a less stress/longevity standpoint.
Please share opinions and thoughts on the issue
