'95 Coolant Leak - front center engine - steam trail
Titan1969
Thanks in advance for any advice.
I have had a great experience with my '95 and thanks to Dan Cragin and Specialty Performance, the car hasn't given me many issues....until now.
I was leaking PS fluid and found the top hose that goes into the reservoir had a bad o-ring, no problem replaced it...took the car for a spin no more PS leak...but steam coming up from center of engine/front. Its definitely coolant, sweet smell.
Its leaking slightly to the drivers side and on top of the A/C compressor, very slight drip.
Im guessing water pump/gasket issues? but wanted your input.
Ill need to drop it off at Specialty Performance, since I trustt they will do a fine job, so just preparing myself for the cost$$$. Car already had new rad, tstat, overflow tanks, hoses and head gaskets in 2017.
T
Titan1969
Thanks to SP and Dan Cragin team. my '95 is purring again no leaks. Needed water pump and a few other recommendations like hoses, etc. Since it was in shop made sense to oil change, change rear pads, and Dan even went ahead and swapped out my rough looking dash cover for a better one after some fresh paint. Lookin great!
xeng yang
