"99 gts rear tires
get bit
SLC, Utah
\"99 gts rear tires
I need a new set of pilots for the rear. The current 335/30/18 pilots don't seem to be wide enough to get to the edge of the factory wheels. Does michelin make a wider tire?
EllowViper
Valrico Florida
Re:
For what it's worth, I picked up a set of new 345-35-18 Bridgestone Expedia S-01 matched asymmetric that are no longer available (discontinued for whatever reason...I think the date stamp on these decode to a 2003 year of manufacture). They are a little wider than the 335-30's Pilots, but almost an inch taller. With my new Elbach springs, these tires really fill the rear wheel well and bite like crazy (of course the Pilots were getting a bit wore/hard). Other than going with a 19" set-up, not many choices to get into a 345 series in an 18" tire.
apun
Re:
www.tirerack lists 2 tires under 345/30-18:
BFGoodrich g-Force T/A Drag Radial
Michelin Pilot Sport Cup (for some reason, it lists rim width as 11.5-12.5" though)
Alex
jpolen21
