A/C COMPRESSOR & ELECTRIC RAD FAN NOT WORKING! BATTERY LIGHT ON! WHAT HAS HAPPENED?
onebadviper
Jackson, Mississippi USA
I have a 1994 RT/10. Today while cruising I noticed the battery light on my dash came on. At the same time the A/C quit cooling and the engine started to heat up. This all started together all of a sudden. I stopped, checked under the hood and the electric fan had quit running. So now the A/C compressor & the rad. electric fan are not working. I drove the car home which was about 15 miles and it ran like nothing was wrong. It would heat up at traffic lights to 200-225 or so, then cool right back off driving. I also ran the dash fan like the A/C would have been on to stay cool. (Top & windows were in) The battery is new & the volts gauge reads 14-15 volts with the engine running. Checked the battery volts and they read 13.2 at the alt. & the alt. output is 14.7 volts with the engine running. What has happened? I checked all the fuses under the dash and all are good. I also checked the two fuses that are by the main electric box where the battery cable hooks up on the drivers side, and they are good too. When you turn the key on the battery light on the dash does not come on until you start the car. I know there are some relays involved, but would it be strange that both the A/C compressor relay and the rad. electric fan relay go out together? And why would these relays make the volts light on the dash come on? I just don't know what to check next. I really don't want to take it to the dealership! Please help.
Thanks,
Warren
(onebadviper)
Our dealership here in Jackson does not get a lot of Vipers in it and I would rather not take it in if at all possible. Any help you could give me would me highly appreciated.
Sincerely,
Warren Wright, Jr.
601-946-1800
BWoodbury
Hawthorn Woods, IL
Mr. Warren Wright, Jr.
This must be the 5th post you have made on this topic. I realize that you have a problem with your car, and this is a great place to come for advise. So I have some for you:
Just ask your question once. Then shut up and wait for someone to answer. You will get much better results...
