ABS Retrofit on my 98 GTS
Joe Dozzo
Golden, CO
Most of my Viper miles are on the street, it's my daily driver from May to October here in Colorado. We also take 3 to 5 high speed "tours" in the western US - there are some spectacular wide open roads across Utah / Nevada / and vicinity!
I also try and make 3 or 4 local track events per year and have attended a couple of formal driving schools including Sebring with the Woodhouse crew last year. I have no real door-to-door SCCA or Viper Days experience, but seriously enjoy high speed lapping on various local race tracks.
I've never had my Viper's brakes fail, anywhere. In all the public road driving, I've never heated the fluid (Castrol SRF) enough to cause any pedal fade. No fluid problems at the track with SRF, but I have ruined 3 sets of tires over the years due to lock-up and flat-spotting.
I chose a VERY agressive solution, probably way more than I need, but I feel very good about the new braking capability I have. I upgraded the front brakes to a 6 piston Baer/Alcon setup from Bobby Archer Motorsports and moved the stock front 4 piston calipers to the rear. I also added an ABS retrofit, again from Bobby Archer Motorsports.
I did all the installation work. The Baer/Alcon setup installed relatively easily, but there was a minor conflict with the front ABS sensors that suggested to me this was the first attempt at this particular combination. Moving the stock front calipers to the rear AND retaining the parking brake is a work in progress. The calipers can be moved (with some machining of the rear uprights and addition of a bracket), but wheel spacers and longer studs are required. For a race car, this may not be a big deal. On what's basically a street car, it's "sub-optimal". My solution (new hats, rotors and bracket) adds more cost, but is a better engineered result, in my opinion. The stock rear calipers can be relocated and used for the parking brake, but at what must be 5 pounds per side, I've decided to chuck them for some slick lightweight Wilwood units from Mark Williams. The ABS installation was well documented (although the wiring diagram could use a bit of improvement, in my opinion) and very straightforward, just time-consuming. In total, 3 days for all aspects and getting the car back on the road - and I don't have the parking brake working just yet. (Oh yeah, one trip to the dealer was required since I do not have a DRB III scantool to test some of the ABS functions)
Now, how does it perform? Bear in mind I just finished the installation this past weekend, but I'm over the moon! I think I need 5 point harness to keep my eyeballs from popping out on hard stops! With the rear tires now contributing much more, braking distances seem MUCH shorter. And no more flatspotting!
BurnR8
Redmond, WA
may I ask what the ABS alone ran you?
try not to smoosh up against the inside of the windshield when you stop....you have some great whoooa for your go now!
congrats!
J
Joe Dozzo
Golden, CO
Sorry all...
I left the prices out only because I didn't want to lock Bobby Archer Motorsports into some corner. Pricing - in my view - is really their business...
Having said that, there seems to have been quite a bit of interest on and off the BBS, so... I paid $5800 for the ABS system - parts price only, as noted above, I did the install - and there was also a $2000 core charge to ensure return of my take-off parts in acceptable condition. I'm expecting that to be returned...
J
Joe Dozzo
Golden, CO
Hey Bug,
I see no reason why not...
I upgraded my front brakes from stock to Baer/Alcons as part of the overall upgrade and only ran into one small hiccup that was easily remedied. With the Alcon setup, an additional bracket is required - essentially, it sits in-between the new caliper and stock caliper mounts - and the bracket as supplied required a small notch be cut for clearance around the ABS sensor.
I also know that another highly respected tuner has installed his brake upgrade on a car already fitted with this same ABS retrofit kit.
Obviously safest bet would be to query StopTech and Snake Brakes before any purchase.
John H
Dyess AFB, TX
What take off parts are they requiring for a core charge? $7800 for just ABS almost justifies trading in for a 2001. Ouch.
John H
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Joe Dozzo:
<HR></BLOCKQUOTE>
Bugeater
Virginia Beach
Joe,
Would you happen to know if the ABS retrofit would work with
aftermarket brake components like the STOPTECH big brake kit?
