ACR front splitter
MarcRoth
Can someone post a picture on how the front splitter cable is attached at the frame or front tube on a 08 ACR. Thanks
redtanrt10
Dana Point CA
Marc, the cable is attached to the radiator support (front tube). Are you trying to re-attach or are you adding a new splitter? I wouldn't be able to send you a picture until tomorrow, but I do have the Prefix install guide with me and can give you their directions on what you need to do. Mike
M
MarcRoth
Doing a new install, Just looked at a customers 10 and seen the U bracket needed. Thanks Marc
redtanrt10
Dana Point CA
Here's from the Prefix book;
1 Remove radiator support closeout. (May be necessary to shield between condensor and upper frame tie bar to protect condenser.)
2 Mount 2 pieces of 3/4 id rubber insulator 1 1/2 " wide.
3. Make cut along the lettering of rubber insulator as to allow to slide on to the upper frame bar.
4. Install rubber insulator onto upper frame tie bar against each side of metal flange of upper tie bar.
5. Install clamps over rubber isolator making sure 1/4" gap between edge of clmap and metal flange.
6. Make sure writing stamped into metal clamp is facing rear of the vehicles
7. Install cables to clamp using 2 bolts, 2 washers and 2 lock nuts.
8. Tighten each bolt to 90 ft lbs of torque.
Sorry no pictures today, I'll send you a pm with their tech number Mike
potterb4
