Almost disaster
sssammm
United Kingdom
Almost lost it..my drivers side wheel sheered off at 60mph,
how i didnt write off the car is a miracle, the bolts sheered off,
the wheel moved out, but never left the car, the disc and caliper
sat down on the inner base of the wheel and held on to it,
it was just a couple of inches from flying off down the road,
only thing mashed is the inner wheel paint, and a couple of studs snapped,
should be able to sort that though.
how it happened i have no idea, i tighten my nuts regularly.
Sonoman
Sonoma Cownty
Re: Almost disaster....
Sheering off a 6-lug is pretty extreme-- I'd be worried that all the lug nuts on every wheel got way over-torqued at some point in the car's life, cracking the studs. Air driver set to 125+ ft-lbs torque might possibly do this. I've seen Grade 8 and higher bolts snap at 30-40% over their normal torque, but they are already stretching at 20-25% over the torque spec.
ssjcreeper
Ohio
Wow. Glad you and the Vipes came out OK. That happened to me once back in the day. Saw my life flash in front of me.
Sonoman
Sonoma Cownty
can new studs be purchased, or do i need a new hub?
The wheel studs are replaceable, MSRP is $17.10 each in the US, but the online places sell 'em for $11-12 each approx.
Don't know if you've looked but there may be some damage to other components that hit the wheel, such as the caliper, or the wheel itself. :omg:
SkyBob
Hudson Valley, NY
Like Sonoman suggested in his post, I would replace all of them, at all four corners.
wikkid
Better check youy wheels as well. May be outnof whack causing this
PatentLaw
Sugar Land, Texas
Not that you heard it here, but someone may have done that to you. I find it very strange that ALL of them let go. Don't you think it is strange? Really?
Allan
La Junta Colorado 81050
hmmmmm......what's up with that really.......can that happen -even if all the planets are aligned?...........december 21st 2012, will all of our lugs fall off? ......:omg:
malcoll
Jacksonville Florida
Yikes.... I bet that tightened more than your nuts....... Seems strange... you see cars all the time running around missing two of five lug nuts..... but all six go at once??? How much life insurance do you have and who is the beneficiary....I'd start there...... Glad you are OK!!!
viper k
i wood be looking at your girlfriend husband! glad your OK!
sssammm
United Kingdom
I also smell sabotage....
got the hub off, no damage anywhere other than the studs and scratched up inside the wheel,
which ive already sanded down and painted
Timnineside
West Michigan
Also check tire wear tie rods and wheel bearings. I've seen a few vehicles in the past have bad wheel bearings and have lugs come loose. I believe this to be the extreme temp change due to high friction.
BS99GTS
Germantown, TN
You say you were going about 60 mph, I assume you were going straight or were you cornering?
Did you recover the old lugs on the studs? Can you post a close-up picture of them?
Bill Pemberton Woodhouse
Blair,Nebraska,USA
As noted by one individual I would really check the rim. I could be hogged at at all the holes from the loose studs and be of questionable use itself?
Axial32
