Buckeye Viper
I have the infamous, "my passenger door will not open from the outside or inside handles, but will open using the emergency latch" problem.
I know that the wiring harness in the hinge is usually the culprit.
HOWEVER, the one thing that I couldn't find on any archived post,
I can still hear the door opening motor run when I hit the button. The door just won't pop open. Even when the door is open using the emergency latch the motor still activates when I hit the outside button or inside lever.
So:
1. Is this still probably the wiring harness.
or
2. I just had my V1 hardwired into my car. Could it be due to something the installers did?
Thank you guys very much in advance for your help.
So:
or
