Anyone have in stock an emergency brake pad?
dsg03svt
San Antonio
I've called my dealerships in San Antonio and they don't have any in stock and say they are backordered till late december...
I would like to get one before then if possible. Any luck?
Viper X
Also try Woodhouse in Nebraska or Tomball Dodge in Houston, TX.
not in any particular order, the calls for new parts should always be....
TATOR
Woodhouse
JonB
the used parts call list should always be:
JonB
Paul Scharf
D
dsg03svt
San Antonio
TATOR
Woodhouse
JonB
JonB
Paul Scharf
Thanks guys. I ended up finding the above out after calling JonB.
Thanks again Jon!
ViperGeorge
Greenwood Village, CO
You should still look for an underlying cause as to why your pads wore out. I assume you didn't ride with the ebrake on. Were they improperly adjusted? Are your rear hubs worn out which might allow the rotor to walk and rub the ebrake pads? I wouldn't think the ebrake pads would wear out unless there was something else wrong. Had the same problem on my 06, turned out to be worn hubs.
No members online now.
wesleyCrowbar
