Anyone have issues with 345/30/19's???
Invasivore
Ft. Lauderdale, FL
Thinking about this tire size in michelin super sports but the diameter is 1.2 inches taller than stock. Anyone have experience with these?
Fuoss484
Tyrone PA
I have them on my car, and the ride is incredible. I recommend them, stick pretty good at stock power with 3.55 gears.
regularsavings
I picked up a set of these about a month ago in that size. Are you worried about them rubbing? My car is lowered with Eibachs and they are fine. As far as the tire goes I have been very happy with them.
hiss highness
yah 19's don't fit on my bbs 18's, would like to go 19 back 18 front but I can live with existing bbs for now, unless they want too much to refinish them this winter
AJ02
Azle Tx.
I'm running that size on the rear of my lowered 02
jay01m
Virginia
Got 19s on my 97 GTS with Eibachs, lowered ~2 inches. I rub so slightly in full turn that I only noticed it when I was under my hood and saw a rub spot on the wheel well. I suspect it's from backing up, but not sure.
Robert Dyck
Pembroke Pines, FL
I have that size and will rub if I hit high speed dips on expressway. However, I'm lowered with Eibach pro street springs AND I have ccw 19" wheels that are offset more outboard. Don't think I would have the issue if I didn't have the offset. Had 355, 25's before with no problems but they discontinued the P Rossos. When my 345's wear out I'm going with the new 355, 25 viper tire. Also remember that you only have a radial increase of the 1.2" dia. to worry about. In my case it was about .7 ".
Paul Hawker
San Diego, Calif, USA
I changed from Nitto's to Pilot Supersports but have 19/20" aftermarket wheels. Need to crank up the shocks a couple turns to prevent rubbing. Still rides pretty low though.
rlamorte
