Jon,
I was thinking that in the 1/4 mile, your main purpose to get to the end of the track as quickly as possible, whereas in an all out top end run, say from 80 to 150, you're looking to gain the most speed to walk away from the other car(s). For example, in the 1/4, a lot of the time you'll see your highest trap speeds without picking up your lowest ET.
What I'm getting at is if you're going to run through 3rd and 4th gears for a speed run, I'm wondering if it's more important to gain the most rpm/speed from each gear to help overcome the increased drag at the top end as you push into the next taller gear (4th and 5th gears) rather than shifting quickly, at lower rpms into the next gear, as you would in the 1/4 mile where you're goal is ET rather than speed.
On the other hand, maybe I need to drink some more coffee and try to wake up...
Christian
