anyone running 295/35/18 fronts?
MoparBoyy
Apopka, FL
I have CCWs on my car in the stock Gen 3 size. VPA is having a deal on the Nittos with 295 fronts vs 275. says fits on the stock rim, wanted to know if anyone was running the larger front and your opinion?
Timnineside
West Michigan
If you don't mind me asking what is the price??? Been thinking about the Nitto's for my Gen 4 and wouldn't mind a bit wider on the front......
Thanks! and from what I have read they will fit all gens with no fitment issues. As MTGTS said I have seen Gen 2-3 with 305's.
-Tim
DrumrBoy
GA
Yep, 295's have zero issues. Not sure about 305's but I know 335's start to rub and cut down your turning radius. Ok for the track, bad for parking. You're fine with 295s.
MoparBoyy
MoparBoyy
Apopka, FL
-Tim
its on there site: $1300 shipped.
MTGTS
Orlando, Fl
**** it with you and your slicks!
and if i got 305s then i need wider wheels.
I have spares if you wanna try and see what they look like and if they'll fit. This Hoosier has a large shoulder and big contact patch compared to normal tires so if they fit anything will.
01viper4me
Probably the only one on here that runs 335's up front as my daily setup. With the Forgeline rims, they don't rub at all even at full lock.
SoCal Rebell
Mission Hills, Ca USA
I've run 335s on the front on track with zero issues on a Gen II, the only problem is you have to make sure the wheels are straight if you open the hood.
DJ'sviper
I have pilot sports, 275/35 18" in the front and 345/30 19" in the back. Looks great on the car. No handling issue's unless I really punch it in first of second. 19 out of 20 it will go straight. Watch out for 20 can end up sideways before you can react. Had same problem with 17" tires, even worse. These are better.
ctrengine
