Anyone using a fuel pump booster???
Snake Bitten
Southern Kalifornia
Is anyone using a fuel pump booster, to increase/regulate the voltage supplied to the fuel pump??? If so, please tell us a bit about it!
Anyone have one that regulates the voltage in relation to rpm's???
LTHL VPR
APEX played around with these on a few Vipers in the past. It worked OK, but it was very limited in how much fuel would actually be added. In addition, it can overwork your fuel pump, causing it to heat up. It all depends on how much your fuel system is taxed now.
-Wayne
utahviper
Utah
I have an MSD boost a pump and it works. It didn't increase my fuel pressure it increased my fuel volume. I do think if you are running your car hard for extended periods of time it might, as bill said,"overwork your fuel pump".
Dale04SS
