BullRider
Searched the forums and could not see anything that would help me for the issue I'm having.
Car is a 2001 RT/10. I started the install intending to go from the bottom, but after spending a few minutes popping the rubber boot off, it was just too tempting to just install from the top. I have no regrets thus far except...
When going to install the new shifter, I can't get the shifter to get in under the ashtray recess in the tranny tunnel.
I've noticed that the B&M surround is a lot taller than the stock one, and the lower pin (with the ball on it) seems longer as well.
Should I just drop the tranny, install the shifter and then raise the tranny back up hoping all will fit again? Should I remove the ash tray recess?
I'm also going to be swapping out my motor and tranny mounts with the poly ones. I took a look under there and my tranny mount is totally shredded! Could that have something to do with things? I would have thought if anything the shredded mount would cause the tranny to sit lower, not higher, but ?
Any input would be greatly appreciated.
