Belanger install instructions
labtec
Maryland
Here are the instructions without pictures for 03-06 Viper. If you contact Belanger they will email you the document. A friend and myself installed the entire system and it fit perfectly. We did not need to remove the plugs or loosen/move motor mounts. I ordered the original manifold gaskets and used instead of the supplied gaskets from Belanger per notes here on the forum. One other note, the headers are bolted together using 3 temp bolts per side, probably for the coating process. The kit supplies the correct bolts with washers so ensure you remove the temp bolts and replace with the supplied bolts.
'03 - '06 VIPER HEADER AND SIDE PIPE EXHAUST ASSEMBLY
INSTALLATION INSTRUCTIONS
HEADER INSTALLATION
1. Remove spark plug wires & plug shields. Remove spark plugs & number them according to their cylinder
number to be reinstalled later into the same cylinders to avoid misfire.
2. Disconnect vacuum hose on brake booster.
3. Disconnect throttle cable.
4. Disconnect positive battery lead on fuse/relay block.
NOTE: Positive cable is live - do not allow cable to touch metal. Wrapping the cable end with
electrical tape during the installation process is recommended.
5. Remove fuse/relay block mounting bracket and set it aside.
6. Remove passenger side windshield wiper and wiper cowl.
7. Remove cold air box below wiper cowl.
8. Remove bolts on coolant reservoir and disconnect hose at heater core - set coolant reservoir aside.
9. Remove both exhaust manifold heat shields.
10. Remove driver and passenger side sills.
11. Disconnect oxygen sensors from both exhaust manifolds.
12. Remove exhaust manifolds and head pipes.
13. Carefully clean any remaining exhaust manifold gasket material from heads.
NOTE: HEADS ARE MADE OF ALUMINUM AND WILL SCORE EASILY.
PREPARING OXYGEN SENSOR WIRES FOR REROUTING: Rear O2sensor routing - same on both sides. IMPORTANT - This kit comes with oxygen sensor harness
extensions. Oxygen sensor wires are not to be cut and
spliced to reach new oxygen sensor positions. If these
wires are cut and lengthened, it will result in faulty
calculations and “CHECK ENGINE” lights.
14. Prior to installation of headers, it will be necessary to
reroute the rear oxygen sensor harnesses:
-Unclip rear oxygen sensor harnesses and plug in
the supplied oxygen sensor harness extensions.
These harnesses will then need to be rerouted to
reach oxygen sensor position behind the catalytic
converters. See photo
PASSENGER SIDE
These oxygen sensor harnesses need to be zip tied away from the headers and exhaust
to avoid melting and chafing of the wires.
15. Headers come in 3 pieces on each side. Take headers apart at the 2 bolt flanges and use a wire brush to clean any
corrosion from the coating that may have seeped in during coating. These surfaces need to be perfectly smooth
to ensure an airtight seal.
16. There are 3 slotted holes on the bottom of header plates for ease of installation.
17. Install header gaskets with 3 header bolts, lock washers and flat washers in the bottom 3 holes matching the slots
in the header plate on both sides.
18. Hang top halves of headers (both sides) on header bolts already holding gaskets to heads. Install header bolts
and washers and finger tighten. Do not torque these bolts yet.
19. Install bottom half of headers on both sides using hardware provided and oxygen sensor-safe high temp silicon.
These flanges are laser cut and machined flat - do not use gaskets.
20. Finish torqueing header bolts to heads.
21. Header bolts should be re-torqued after 1,000 miles to avoid bolts loosening. This process need only be done
one time after installation.
22. Reinstall oxygen sensors into new location on headers.
23. Reinstall steps # 1 through # 8 on front page under “Header Installation” in reverse order.
** NOTE: Do not weld the stock front hanger bracket to Belanger’s header hookup (90º elbow with flange). The stock
bracket setup is for use with the stock OEM flex pipe only.
Your Viper has adjustable, slotted motor mounts. In some cases it may be necessary to adjust motor mounts to
center header collector in hole.
NOTE: WRAPPING HEADERS WITH HEAT WRAP WILL DESTROY THE TUBING & THE COATING!
EXHAUST INSTALLATION
To eliminate the stock crossover tailpipe assembly:
1. Removal of aluminum belly pan is necessary when eliminating stock crossover tailpipes.
2. Remove stock crossover tailpipe assembly.
3. Install side exhaust with oxygen sensor-safe high temp silicon on header 3 bolt flange with the hardware
provided.
4. Install tailpipe into slip fit at rear end of the muffler.
5. Install and slightly tighten band clamps to allow for fine adjustment and centering of tips.
NOTES: The tailpipe is a bolt on setup with a stainless steel band clamp - this system works well, but I recommend putting about ½ “ to 3/4 “ weld from the tailpipe to the muffler, along with the band clamp to prevent the tailpipe from rotating in the muffler.
The tailpipe section is designed to fit perfectly so that the stainless tip will sit just forward of the center of the outlet hole (see picture below). On some Vipers this tailpipe section might be slightly too long - better to cut a little off to fit than to have to add length.
Exhaust will grow in length up to 3/8" after it heats up. Therefore, it is necessary to position exhaust tip just forward of center to allow for proper clearance.
See figure below:
6. Temporarily install side sills in order to center and align tips in side sill outlet.
7. Remove side sill and tighten band clamps.
8. Reinstall side sills.
This product, in conjunction with your Viper’s computer, requires at least 500 miles to recalibrate for
air/fuel, timing and other critical settings to “dial in” properly. Running your Viper on a dynamometer
(dyno) during this critical re-calibration time will result in poor “dyno” numbers and your Viper motor
running hot. This action voids the product warranty and the A.E.C. coating warranty on our product.
THESE PRODUCTS ARE FOR OFF-ROAD OR TRACK USE ONLY
Boxer12
Colorado High Country
If its a Gen IV, just remember that you have to raise the engine an inch or so (try just loosening the mounts) to get the OEM exhaust out. Otherwise, its pretty straight forward once you get the side sills removed.
JKGiant
