Best clutch for the GTS
GTSGUY
I have a N/A 2000 GTS with approx 580 rwhp and my clutch is done. I go the drag strip and the car has drag radials.
What clutch would you recommend for thsi car. The stock clutch did not last with the current whp.
99 R/T 10
Enterprise, AL USA
A Spec III is real nice. Spec II would hold up well too. Surprised the stock clutch gave out. How many miles did you have on it?
Jack B
NE Ohio
I had a spec iii and had a hard time shifting, it is way heavier than the the oem disk. They will sell you a custom petal type disk which is lighter and grabs harder. It is actually like the old spec iii which was a better set up.
Red Shift
USA
I'm surprised the stock clutch isn't holding up. Heard of lots of higher power guys running it no problem. It's super cheap too.
Red Snake
NashVegas
Stock pressure plate with a 6 puck disk would be an improvement over a totally stock setup. :2tu:
thaimonkee
Bethesda
OEM for me. Im making 560 rwhp with an N/A setup and its holding fine. Best thing about it is its hella cheap!
2001 GTS
Charlotte, NC
600rwhp NA here...went through a Centerforce in one track day, so now I just run stock and it is holding up much better!
G
GTSGUY
I finally decided to go with the McLeod twin disc(alum) it is more$$ and probably a bit too much for the hp I have, but it should be better in the long run.
SKY1960
