Boost guage vacuum soure
viper04
I was wondering where you guys and gals that are running a boost guage (Paxton-Turbo cars) are getting your vacuum soure from? I know manifold vacuum, brake booster and Idle air bypass can be used, if I'm not mistaken. Let me know what vacuum soure you guys are useing, if you have any picture please post it. Thanks in advance.
VIPER R
I put a tee fitting into the brake line, 7 years and no problems.
Nixon's SRT
If you are running the split second box it should be under your dash. I would T off that
V
viper04
Nixon
Thanks for the reply, not going to run the split second box. Where are you running your?
Nixon's SRT
Mine goes through to the engine bay and T'd into to a line from my boost controller
From my paxton car,
Look at the positive battery post on the fuse box and about 4 inches up at the 10 o'clock position, thats the T that was inserted to the line going from the intake manifold to the brake booster. My gauge, FMU, blowoff, and split second all started from that location
V
viper04
Nixon's
Thanks for the picture, looks better that I was thinking.
xeng yang
