Brake upgrade!
jojogts
So I'm wanting to do a brake upgrade, does anybody have a set of gen 3 brake calipers there wanting to unload...
X-Metal
Indiana
i have a brand new set of drilled and slotted rotors. they are sized for the big brake kit on a gen2. $400 for all 4
J
jojogts
Sounds good I might take you up on that! But first I need to find the calipers... Are gen 3 and 4 brakes Calipers the same?
J
jojogts
I've heard of Daves big brakes but not Toms big brakes! I'll have to search them, thanks...
J
jojogts
Thank you! Running 20's on the rear really makes the brakes look like crap...
J
jojogts
^^^. Thanks Mark for the info but like everything money is the key factor. So Daves big brake kit seems to be my best option. I'm trying to piece together the parts to save as much money as I can... I found some gen 4 calipers on eBay are they the same as the gen 3?
NI-KA
Canton, Ohio
I have a used front big brake kit that I will be taking off of my '97 GEN II. It would come complete with the rotors, SRT-10 calipers, stainless lines, and the needed SRT-10 mounting brackets. If your interested send me a PM.
KNG SNKE
Portsmouth, Rhode Island
Same calipers.
J
jojogts
So I've looked on davesbigbrakes website and I'm not 100% sure what all I have to get! I would like to use my front calipers if possible, so can I put the fronts on the back and put srt calipers on the front? Please give me as much info as can.. Also car is a 2000 gts non abs.
vancouver-gts
Vancouver BC
Yes, you can order the DBB kit for either, 14" srT brakes on front with your 13" front brakes/rotors moved to the back. Or have 14" all four corners, from JonB . With 14" all corners you'll need 4 srT front rotors for proper offset for the rear . 14" front you install the adapter block and the srT caliper,adding the cnc machined spacers [4in the kit] and longer wheel nuts.No cutting required front or rear. The rear adapter block is slightly different from the front block ,mounting hole centers are for your 13" front calipers [much smaller than the srT calipers] . The e-brake assembly is also specific to 14" or 13" rotors so you must make sure you don't get a 14" e-brake assembly that's further away and different offset on a 13" skinnier rotor.Going to 14" front with your 13" rear gives a better brake bias that doesn't require much fussing with the proportioning valve.The 13" front rotor will still look small in a big wheel though, so make sure what you want and decide to go with.
Comparison
Andrew2KRT10
New York, where else?
My 2 cents, watch that e-brake line as it runs over the front of the control arm, tends to almost rest on the corner of the control arm and can wear through quick. I re-constructed my bracket with a blank from Dave, problem solved.
AZTVR
Chandler AZ
Do you happen to have a photo ? I just installed a DBB e-brake kit 2 weeks ago and "kluged" something myself to prevent the chafing you are warning about. However, I would always like to see a more professional or more elegant solution than my tie wraps and rubber hose !
KNG SNKE
Wear through quick? I have never heard of it wearing through and I have had the kit on my car for a while now. It is metal shielding with a cable in it, would take a very long time to wear through.
Cerevo
