Cam Specs
LTHL VPR
Mike-
the problem is that the manual everyone is refering to lists the 'advertised' numbers as opposed to the industry standard '@ .050' numbers. Unfortunately, I have not been able to find a consistent formula/% for converting advertised to the proper formula. I will try and get the numbers for you and give you a ring.
Whatever you do, DO NOT order a cam using the advertised numbers unless you are planning to build a Top Fuel Dragster....#$@%
-Wayne (LTHL VPR)
rlamorte
