Can driving on a flat tire set a Check Engine Light from the ABS? ---
alwayscode390
STL
I got in my car after letting it sit for 2-3 days ( I have been driving it daily ) and noticed I had a flat tire.
Well, my lighter wasnt working so I couldnt use my portable air compressor.
I drove it 1 mile up the road and my check engine light came on.
Could the ABS pick up the difference in tire/wheel diameter and throw a Check Engine Code or would an ABS light more likely come on (if there is one)?
I will hook up my SCT scanner and check the code once I get time, but was wondering if you guys could point me in the right direction before then.
Its a 2001 GTS, thanks :) ---
AZTVR
Chandler AZ
Yes, I bet that you will find that the code is an ABS code, (depending on how flat the tire was). However, I had a flat on the rear of my '02 GTS that I did not see before I drove the car to work. I noticed the bad handling behavior part way there and drove the final 2 miles with the tire very low. It never did set off the check engine light. The tire was low enough that I overheated the sidewall and basically rendered the tire unsafe for future use.
As I understand it, there are several potential codes that COULD be set from speed sensor problem...around 5 for a 2001 Viper...as per the 2001 Service Manual.
hemihead
Commerce Township, MI
I threw the tone wheel off my car last summer and got and ABS light, the code indicated a bad wheel speed sensor. I'm sure you would have gotten an ABS light and not an engine light for the wheel speed sensor.
