Can i change the tranny fluid myself?
SPARKY
I was just wondering if anyone here has changed there own transmission fluid? What kind of fluid do i buy and where do i get it?
SPARKY
Where is the drain plug at? Where do you put the fluid back in at?
Janni
Raleigh, NC, USA
There are drain and fill plugs in the tranny. Service Manual has detailed drawings / instructions for procedure.
MHQC
Quebec, Canada
Sparky, easy job. Did it 2 months ago. The drain plug is the one on the bottom tail end (towards the rear of the tranny on the passenger side if I remember). The fill plug is on the driver side up and in middle. You will have to remove that plate the covers the tranny; there are about 12 bolts. Should take about 30 minutes to do. Enjoy.
95Viper
Phoenix
Trans - Mopar from dealer - synthetic, clear fluid (not red dextron) used in current Vipers, need 4 quarts. Easy to do with lift...take off trans skid plate, open drain plug, drain, close, open fill plug, get 3-4 inch tube with OD the same as ID of fill hole, insert in trans and squeeze bottle in other end. This is a little tricky and messy because you need to try to cram the bottle up wherever you can to get it higher than the fill hole. I put almost all 4 quarts in and when I pulled out the tube a bunch leaked out which is good. Just have a funnel ready and wait until it stops, then plug.
Jack B
NE Ohio
Sparky:
do a search for "Viper Fluids", it was a post that appeared several time. It appeared in the first week of May/03. The poster did a very nice job. The amounts and types of fluids are addressed in detail.
slaughterj
How far back is the drain plug, e.g., in relation to the differential fluid plug on the far back passenger side?
Qualitywires.com
Louisville, KY
Make sure your Viper doesn't have an automatic transmission. The procedures are different for that. FYI. Hope I was helpful and knowledgable.
sbkim
Bloomingdale, IL
Do you fill until it drips? How do you know when it's full? I have never done a manual tranny fluid change but I think it's easier than auto since you don't have to have your engine on, right?
95Viper
Phoenix
Read above, fill until it drips out, have funnel ready, when stops, plug. Do not have engine on.
