Can I get some help, Please?
trymyz
I've searched here and all over the net with no luck. I was hoping that someone could either email the pinouts of the ecm for a gen 4 (preferred) or at the least tell me where I can pull the throttle positions signal from. Thanks.
T
trymyz
Thanks, will check into that. Was hoping that someone knew what wire to tap for throttle position either at the ecm or at the throttle body. I guess I'll just have to use a volt meter at the plug.
T
trymyz
Guess I'll have to pull out the volt meter.
Viperizer
Hi, Just so happens I am working on a wiring project on a 2010...
You are looking for the Black and Orange connector...
PIN 22 is TP # 2 Signal # 2 BR/LG
PIN 23 is TP #1 Signal #1 BR/OR
PIN 24 is TP #2 Signal #1 BR/RD
PIN 33 is TP #1 signal #2 BR/DG
The pins are number right to left 3 row down starts pin 20 on far right when looking at connector
Pin 29 starts bottom row...lower right corner...count left to pin 33.
Hope this helps you with your project.
Ron
