cat delete with v-bands?
jc411
i am running stock cats and stock exhaust
if i remove the cats and run v-bands to make it easy to swap out will the 2.5" v-bands fit in the side sills?
what about 3" cat delete pipe with 3" v-bands... will those fit in the side sills?
I know most people just weld in the straight pipes or hi flow cats but i want something that is easy on and easy off so i can put back the stock cats if needed...
Camfab
SoCal
Here's my car with the stock headpipes transitioning to 3" High flow cats with V-bands
Here's my car with SVS headers V-banded with 3" High flow cats
If you'd like I can take pics of my car without cats and V-bands as well as 3" V-band conversion on the stock cats. I've done all the configurations.
LPDesRoche
Sunbury, NC
They will fit fine. I have 3" V bands on my cats and cat delete pipes. Works like a champ. I put the V bands on each end of the pipe and cats so they just unbolt and slide out of the way. Makes for a very easy swap if I ever decided to change back.:D
tbone96
