ccw track rims
1a-play
can I use 17 x 13 3 piece ccw/purner rims in the front and back on a 2000 gts? if so what size tires are used? thanks -- if anyone has some tires laying around please let me know
REDSLED
Bakersfield, CA USA
Yes, IF you have the stock brake set up. 13" on the front is pretty wide, but doable. A 315 tire will fit nice up front with 335's on the back. Call John at CCW, they do sell tires as well. Sometimes take-offs.
1a-play
I have a set of 6 already that I just bought used but wasn't sure if I could use the 13 wide rim in the front also- thanks for the help
I have a set of 12.5x17 CCWs up front. They will rub the sway bar unless you use spacers. 315's are GREAT up front. I've run 335's all around and THE CAR IS A FREAKING MONSTER IN THE CORNERS. However, your hood's wheel arches won't like them.
ctrengine
