Changing oil made easy.
Jack B
NE Ohio
I would like to share some shortcuts that I use to simplify the oil changing procedure.
Tools needed
a. Hydraulic floor jack and jack stand - Northern Tool has a low profile jack that does a good job of lifting the Viper for any undercarraige work. At $140, it is a steal and a must for any Viper owner.
b. Cup type filter wrench - This type of wrench is turned with a 3/8" ratchet. The wrench is sized to fit a specific filter (it fits over the end of the filter). The filter on the Viper is physically a Fram PH15.
c. 3/8" swivel-head ratchet.
d. Pan to catch oil from drain plug and filter - Any good auto parts store should have a oil drain pan. The one I have has a 24" diameter and is 5" in height. It actually has a drain hole in the top and pouring snout on the side for disposal. I save one/two gallon plastic bottles (detergent/bleach) to dispose of the oil.
e. 10" Flat File and small hammer - I remove the file from the wooden handle and use the sharp (handle side) point to puncture a hole in the oil filter to drain the oil out prior to removing the filter.
d. Two filter magnets - these attach to the filter and trap iron particles flowing thru the filter. They are reusable. They can be purchased from Gratiot's.
The Oil Change.
1. Jack up the drivers side approximately 10-12" and put jack stand towards the front of engine and on the drivers side. This pools the oil on the passenger side where the drain plug is located.
2. Drain oil into pan and clean the magnet on the drain plug. Replace the drain plug.
3. Use the cup type filter wrench/3/8" ratchet and turn the filter one complete turn (360 degrees)
4. Puncture a hole in the lowest part of the filter with the pointed side of the 10" flat file. Turn the filter so that the puncture hole is at six-o-clock on the spin axis. Let the oil drain for a couple of minutes.
Most of the oil will drip straight down into the pan. Wrap a shop rag around the rear lower suspension arm. This will stop the oil from dripping down the arm. If done carefully, you won't get a drop on the ground.
5. After the oil stops dripping remove the filter and replace with the new filter. Place a thin film of grease on the gasket. This will aid in removing the filter the next time. Hand tighten the filter, then turn approximately one full turn with the wrench. Apply the two magnets on the exterior of the filter.
6. Place the two quart funnel in the passenger side valve cover breather opening. The large funnel will be supported by the valve cover and blower assembly. Fill with ten quarts of synthetic oil (good choices; Mobil 1, Redline or Royal Purple)
7. Start the car and immediately turn off engine. Repeat this same sequence several times till you build up partial oil pressure. Now let car run for a couple of minutes and check for oil leaks. Shut off engine wait approximately five minutes and check the oil level. Depending on how much oil was removed and replaced it is quite likely that may have to add as much as a another full quart.
I realize that there is more than one way to accomplish this task and I don't want to infer that this is the only way. Hopefully this will help someone one hasn't changed their oil by themselves. If anyone has any additional tips please post them.
nutsRT
Oak Park,ca,usa
Here is my method of doing an oil change. I buy my oil and filter at an autoparts retailer. $4.36 a quart for Mobil 1 and $6 for a Mobil 1 filter. I go to a local Valvoline(or other chain oil changer) lube and oil change facility and call and tell them I am bringing in a Viper with my own stuff for an oil change.( I also take my other vehicles here). Here are the bennies.
1. I drive the car in, open the hood and monitor the entire oil change process(the manager of the store gets real excited when a Viper is in the bay,it draws attention).
2.I really manage the whole process,as I am in the bay(also answering questions to both the employees and customers)ensuring the old oil gets out and the correct amount of oil goes in.(9.5 qts for a 2000)
3.I also convince the the manager to let me in the "hole" where I can visually inspect the underside of my car for leaks,loose or missing screws or other abnormalities.
4. No muss, no jacks, no 9 qts of used oil plus filter to dispose
plus an easy visual inspection of the under belly.
5. Cost $20($5 tip) plus material. Peace of mind at a reasonable cost
Steve 00RT/10
Michigan
I also use the Quick Lube method. Bring my own oil and filter(Amsoil), go into the pit, put the new filter on myself, and check the bottom of the car out. Cost--$10 I do bring a couple of other vehicles there as well for the standard procedure.
Steve
Peter A
Alpharetta, Ga USA
I suggest you add the step of filling the new oil filter with fresh oil before you install it. This will reduce the time it takes for the engine to fill the system and build oil pressure.
Mpcc
