VNMOUS
I've been out of the viper for a few months after having an ACL reconstruciton on my clutch leg. Anyway, my trickle charger failed me and my battery is dead. I replaced it with a yellow top 34/78 Optima today and she cranked up fine. In the process of setting the time and radio stations I had the key in the on position. All of the idiot lights came on but the engine light began flashing after about 10 seconds. It flashed 11 times then a quick 12th at which point it stayed illuminated. I don't remember it doing this before so I'm pretty sure there is some sort of error code. I did the battery temperature sensor mod but the light still flashes. The only other mod I have that might send an error code is a set of Random Tech high flow cats. I was hoping someone with a stock setup as well as someone with an Optima and someone with Random Techs could check and see what their check engine light does with the key in the on position but the car off. I don't have time to get the car scanned for a few weeks and I just don't want to have the computer robbing me of power or over/under charging the battery.
