Changing from cast iron manifoilds and the restrictive 2.5" exhaust should lean the engine out to close to the mixture you want. Going rich usually means part throttle and I would lay odds that the rear 02 sensor prograis the culprit. Either the 02 simulators should mostly finish the check engine light, but I like the spark plug non-foulers myself. I wrote an Illustrated Upgrade for it, but I'm not sure if it's still there or not.
A GOOD tuner is the best solution of course. With an SCT tuner he can adjust your fuel maps, increase your timing etc. A good tune usually adds 25-45rwhp. If you have other mods to do, then do the non-foulers mod and get the tune after you do the other mods. Driving your car if it is running too rich is ******* the rings so I wouldn't do it for many miles. Contact your regional pres of the VCA for their recommended Tuners in your area.
Ted
