Clear Rear Turn Signals Gen1 & Gen 2
Voodoo Rob
Cleveland, OH
Has anyone bought a set? Trying to get feedback on fit and finish before I purchase them. They are on eBay item 400182503186.
nutkees
Winkel, the Netherlands
I got clear signals on my Gen II, but I believe mine are of an asian car, but the previous owner didn't recall which type.
Vipuronr
Nice on black....I'd be interested, if anyone has experience.:2tu:
Jance GTS
Oklahoma City, Oklahoma
I sent in my OEM units to Jason at Klearz and he hooked me up with a set. Fit and finish is good and they look a lot better than the stock amber lenses.
^^^^ Not aligned yet.
You can see the bulbs, but mine aren't stock bulbs.
I took mine a step further on the lights to make mine completely different. I'm using a pair of switch back LEDs bulbs and rewired the sockets for the special bulbs.
The LED's are designed to alternate colors for different functions. I'm using White/Amber bulbs. The entire lenses lights up amber for turn signals and solid white for reverse lights.
Since the lenses are completely clear i didn't see the need to have separate housings for each function. The end result looks amazing and no one would ever know it's not stock!
V
Voodoo Rob
Cleveland, OH
Jance GTS, where you bought your set is the company doing the lisitng on eBay. I haven't pulled the carpet off the back, is it an easy install? I was going to go with the clear rear turn signals and chrome covered bulbs to hide the color when off. I also wanted to get the clear fronts but cannot find them.
ZYellow01RT
Am I missing something?
If you go to the Klearz.com website, these same clear rear turn signals cost only $75/pair, plus $18 for shipping (within U.S.).
However, that eBay listing (above, #400182503186), shows that the same pair is going for a starting price of $158, with a Buy It Now price of $172, plus another $20.42 for shipping!
Also, the Klearz.com website says that these are only for a 1996-2002, while the eBay listing shows 1992-2002. I emailed Klearz.com to see if they will fit in my '95.
Looks like a li't more research is needed!
Jance GTS
Very easy install just time consuming. Once you get the carpet out there will be rubber grommets covering the holes. It's a PITA to try to get a socket in the holes to turn the plastic nuts. Once you have them unbolted just pull them out and unhook the lights.
Klearz hooked me up with a free set, but I ended up dropping one light that broke off the stud bolt from the housing. I had to order another light and it didn't come with any studs, so you might have to remove your factory studs and install them on the new ones.
I also got my front clear marker lights from Klearz. Jason is a nice guy and he will work with you if you have any problems. :headbang:
Jance GTS
Oh BTW. You can buy just the clear lenses for $75 and the housings are another $75. I had black housing's but I didn't like them so I sent them back and got the silver housings instead.
To me the black housing's looked like I was missing a lense from a distance. That's my car on his site. I need to send him some new pics :)
97snk
I think the stock ones look better, all clear looks out of place...
Mine are painted black...
Dale04SS
