HaWiiLuVeR
ive posted here a couple times before, but not for a while. ive got a 69 charger with a 440 that i made an adapter to put a t56 behind it. im using a weber 12" alum flywheel and clutch setup, and the viper slave/TO to disengage the clutch. im also using the factory master cylinder to feed the slave, and i dont think its displacing enough fluid to fully disengaged the clutch.
i was wondering if anyone on this board would know the bore and stroke of the master cylinder. i am looking at getting a wilwood master cylinder, but need to know what size the factory is first. are there any bolt-on upgrades to increase the fluid of the stock viper system?
thanks for your time and help.
