Clutch Pedal-Why So High???
VENM8R
The Last Frontier
When you say too "high" are you talking about the length the pedal travels? I ask because I find it a little hard to push the clutch in all the way. The other pedals are then situated too close when adjusted so that I can push the clutch in.
If this "Roe" conversion takes care of this minor anomaly I would certainly purchase one.
Gisler
Switzerland
Hello, had the same problem, could not press the clutch all the way down and sit comfortable with the accelerater and the brake pedal, so I just extended the alluminium plate on the clutch pedal for about 1 inch and now all the pedal positions are fine for me. It just takes 1 small piece of steel with two holes in it, the pedal plate is a screw on thing.
Roffle Waffle
based on what others have written the roe piece helps a little, but not a 100% fix. I'm going to try and modify the factory piece to be even shorter
tbone96
