Clutch pedal
tim bob
on my 94 I got in my car and the clutch pedal just goes to the floor no pressure on pedal? Thanks in advance
Check clutch reservoir for fluid level...also look for a puddle of fluid underneath car which may or may not be there. I am betting on failed clutch slave cylinder.
By the way, be sure car is in neutral before attempting to start it !!
T
tim bob
Thanks Steve no puddle or anything under the car I’ll check fluid also is a clutch slave cylinder a big deal to fix?
T
tim bob
Steve is the reservoir for clutch mounted on dr side close to the brake master cylinder? On the cap it says fill to step there’s very little fluid in it but everything seems to be dry? Thanks tim
techanvi
