condensation in car
whatthe
Have 94 rt, with air conditioner on water is coming in car on passenger side any ideas? someone said maybe a plugged line any idea how to check this ? thanks for any help Steve
scottmarston
Meridian, Idaho
Yeah, your condensate drain line is probably plugged. Not much help...I'm not an A/C guru, but I think your evaporator is located on the passenger side. This navigates the low pressure (cold) gas through a coil and is responsible for cooling the air and attracting moisture in the air that the fan blows over it before it reaches your cab. Condensate is built up on the evaporator coil, drips off and needs to drain out somewhere...yours doesn't seem to be draining out. If it is plugged, I would find out where it is supposed to drip out of your car and work backwards till you find the plug.
KNG SNKE
Portsmouth, Rhode Island
Passenger side drain tube. Remove the tube and stick a soft speaker wire in the hole or something soft that won't damage the core. The foam inside sometimes falls and causes the water to leak.
SKY1960
