Hi,
i have a problem with my 01 GTS and hope that somebody can help.
Today in morning i started the car and after 1 minute of drive i looked at the coolant temp.gauge and it showed 250!
I stopped and take a look under the hood but everythink was ok.
Both waterhoses (from Thermostat to pump and from pump to radiator had the same temperarture,fan is also working and waterpump must be also ok because the car heats from the blower if i want.
If i turn the ignition off and on (also when the car is cooled down) the temp gauge rise to 250 in 1 second and stands there![dunno :dunno: :dunno:](/vca/styles/default/xenforo/smilies/dunno.gif)
Also the MIL lamp lights since 2 days,but there wasnt the issue with the coolant temp thing.
Is there a common problem that maybe somebody know like a broken coolant temperature sensor or anything like that?
Only thing i have done yesterday evening is i have changed to AB wires but i am sure everything is connected properly (i am a car mechanic)
I know i must to the dealer to look with the diagnostic tool to see why the MIL lamp has came up 2 days before.
Car is standard except for K&Ns,smooth tubes,muffler delete and AB wires.
Hopefully someone can comment,
regards from overseas
Daniel
Daniel
