Matt M PA
I remember much talk about this in the past, yet cannot remember exactly what the "right" answer is. Where should the Temp gauge read on my 2000 GTS? (If memory serves me, the manual says anyplace but in the red is okay.)
It was around 75 degrees tonight, and while cruising the gauge seemed to hover around 190-200. When driving slowly through town, or stopped, it would rise about halfway or a bit more towards the 225 mark. I have never seen it go past 225 regardless of the outside temp. It only just dips below 190 when cruising for about a mile..and then, it is not even the needle width away.
Before it was put away for the winter, I seem to remember it running at the same temps.
So, what exactly is "normal"? Should I be concerned about the known water pump issue? I doubt it is a "burping" problem as the Wizard had to do that after the 999 recall.
Thanks folks.
One more thing that may-may not matter. The heater blows HOT out of the floor vents. I thought that a good hot heater could mean a good water pump.
Thanks folks.
