couple comments
SEEEEYA
clinton township Mich.
Just amazed as to how much quieter my 06 i now after switching to mobil 1 15-50, have a little higher oil pressure, hopefully thats ok
also a lazy question while on my back under the car I see 2 zerk fittings on the lower front control arms in "plain " view, are there any more "hidden " ones I need to look for??
next is high flows and a cat back thats coming in the mail:2tu:
Sonoman
Sonoma Cownty
The upper ball joint zerk fittings point straight up, so I've only done them with the wheel removed, but if you have a grease gun with a right angle end it could be done (maybe). As wide as the wheels are, I wouldn't bother with trying to do it. But then, once you've done ride height adjustable coilovers, you get used to taking the wheels off and on a lot to dial in the ride height. The car floor jacks easily and if you have a large torque wrench with a 19mm deep socket, it is a breeze to remove a wheel, even while being careful to avoid whacking the fancy red brake calipers.
SKY1960
