V10 ACR
tAll,
If you race at all, or if your car has more than 10,000 miles, you need to check your motor mounts ASAP. I had my car up on a lift and saw what looked like damage from a tranny that was shifting. I decided to change out the motor and tranny mounts just to have more heavy duty connections to the frame. When we took off the mounts, they were obviously deformed and had totally come apart. The safety was the only thing holding them together. With the new parts from Woodhouse the car is much tighter and more responsive. I drove at a viper days on a track I had been on before and cut 8 seconds off my time. On the 1/8 mile drags my time dropped by 0.2 secs.
It is hard to see if the mounts are shot by visual inspection, so this can easily be missed.
Right mount deformed
Left mount with visible split
Static, they dont look so bad
When you pick them up, they just fall apart
Only the safety was keeping the motor from spinning off the frame
New mounts from Woodhouse used to replace the old ones. Much tighter. Much more vibration noticable for the first 200 miles or so with the new mounts. Still more than the old ones, but it is obvious why. Don't take a chance, swap out your mounts or at least have them inspected.
