i am considering a daves big brake upgrade.
do you have to use a prop valve and if so is it an easy install.
cheers!
i am actually trying to fit one at present. there is restricted room to change one ,if you have fingers like jumbo sausages it might be a problem.
it is a willwod prop valve with my daves big brake kit and have noticed the out port of the prop valve is too small to take the 97 gts brake line fitting which is causing me a major delay in the install.
has anyone reading this come across this before and if so what is the best way to connect it.
if not any ideas ??
thanks!
